VU+ duo2 images
plaskotki
Hi guys, suppose to be getting VU+ duo2 tomorrow. I am trying to establish which image will be preloaded by the factory and whether or not you experts feel I should upload a different image and if so, which one would you recommend? Would really appreciate your advice. I am switching over from Icecrypt s4000HD PVR.
The pre-loaded image should be the one from vuplus:
http://code.vuplus.com/
The Black Hole images are designed, for the VU+ receivers, I've tried a few others, including Open Black Hole, but always revert back to Black Hole, as it has more options, for me, to set up the receiver as I like.
