Vu+ Duo2 one of DVBS-S2 tuner is busy and the REC lamp blinks
serch826
Sometimes one of the DVBS-S2 tuner is busy and the REC lamp blinks, the box crashes when in the settings menu trying to check with satfinder on the tuner that is busy with rec, can't find any solution for this issue.
Crashlog attached, thank you in advance for your help
Verify if someone outside your network uses your box to see TV
Hi thanks for your answer, no i don't thiks så. i've configured my WEBIF with different ports, not the default one, i think there's some bug because the chrash when checking the tuner on satfinder.
I've ignored the SatFinder plugin problem because you have mentioned in the thread title the REC icon blinking and this kind of issue is present when someone see TV outside your network ...
Change ports not protect you against TV-tweakers who want to see TV from your box.
Well, just to be sure, you could disconnect your box from your network...
And also check if any timers is active: this is the 3rd reason for a blinking rec icon.
Thanks, I've tested with another image which also occurs, there is no timmer is activated, I closed portförwardnig in my router and obviously the problem go away, I think it's a very weird problem because I have changed the port and password, several times, but it does not help, perhaps the fault lis in the Vu?
NO! Your box doesen't had any bug.
It's so clear that someone outside your home, via Internet, uses your box to see TV.
It's also confirmed by you when you wrote: "When I've closed portforwarding in my router and obviously the problem go away".
Well i fixed this, just portforwarded the HTTPS own port in my router and don't portfowarded the HTTP one, så now those unapproved rec or sreaming has completely disappeared.
