Hello everybody!!!! Good day!!!
i need your opinion and help!
i have vu duo2 and edision osmini dvb s2 receivers
i noticed that edision osmini has more sensitive tuner-better tunner than vuduo2.one costs 90e and the vu is more more expensive.the edision has better db's signal espesially in bad weather etc...
I have to say that i have tested the 2 receivers in same setup(motor usals-same lnb-same cables)
What can i do to fix vuduo2 tuner sensitivity?What image should i use?What can i do?
Thank you very much for your help!!
I am waiting for your answers!!
