Vu duo2 picon
asif007
Hi I was just wondering if I rescan the satellite channels and replace few channels which has changed frequencies but I lose the picon as well how do I replace the picon with it is there some settings I need to go into I have downloaded the picon again and restarted the box but it doesn't work please can somebody help me thank you
Picon files are searched and associated to channels by means of the file name which includes the channel reference.
If a channel has changed its frequency, it's likely that the file name will no longer match its reference.
Neither downloading again the picon set will fix the problem, if the picon author has not changed the file names.
So you have to manually perform this rename job on the files stored on your box.
