VU DUO2 stream problem
kenderie
Hi everybody!
I have a problem.
I have a Vu+ Duo2 box.
It is set to access FTP from the Internet using the internal hard drive (port 21).
The transmission also works over intenet (port 9091).
However, streaming does not work over the Internet, only on the local area network.
I tried using vuplusplayer on android phone and using KODI with PC with vu+/enigma2 client and simple iptv client plugins.
In the router I did portforward the 8001 and 8002 ports to the box.
I have a ddns address.
What might be the problem?
It worked on my old EVO Enfinity box.
Thnx/Kendeice
Hi everybody!
I have a problem.
Thnx/Kendeice
kenderie, did you found a solution to the problem? I have Vu + Zero, Black Magic image ... video stream in local network is working just fine, over Internet does not work!
Problem MUST be in receiver and in image, there are no obstacles with closed ports on the router, DMZ is open everything works except stream... I hate my Vu + Zero
