VU + DUO2 Tuner problem
Norman
Hi, i have Vuo Duo 2 set up with 2 X 2 twin tuners all DVB-S2.
Tuner A Advanced [motorised LNB]
Tuner B Second cable motorised LNB Tuner A.
Tuner C Positioner : USUALS
Tuner D Single [fixed dish 28.2 deg E]
All tuners used to work fine until recently,
The problem,
Cannot get tuner B to work when selected,[ if other tuners busy]
I have swapped the cables round going to A and B tuners on the LNB ,The LNB works on both cables whilst connecting to tuner A ,However cannot get B to work, it shows Red whilst selected but no SNR 0%, No Picture,
Could this be glitch in the latest Blackhole 2.1.4 firmware,has anyone else had problems,or has part twin tuner gone down,
Ruled out cable ,ruled out LNB as both work on tuner A.
All help appreciated,
Thanks in advance for reading this Norman
