Request VU+ DUO2 Tuner/satelite setup
Jan Hagen
Hi
I updated my image yesterday and now I`ve lost all my settings in tuner/satellite setup. I have only one tuner active in my house and I have two positions of satellites, 4,8E and 0,8W.
Could someone please give me a feedback/how to on what to do? I have a tuner A and tuner B, which one should I disable and which one should I use + what are the settings?
Also the satellites, which position is A and which one is position B?
Use whichever tuner has the cable going into it.
Set the Tuner to simple, mode diseqc A/B, and try each option:
A = 4.8E
B = 0.8W
try manually scanning in, or viewing, some channels, if that doesn't work try
A = 0.8W
B = 4.8E
Ok great, thanks :-)
Do you know if there is any good solution for streaming on WAN outside LAN/WLAN? I have an Iphone and Ipad that would be nice to use on vacation and weekends away from home :-) Any usefull addons on this? Reccomend also other useful stuff if you have any :-)
I`m usind OpenPli image (latest).
