VU+DUO2 Tuners
riccardomagno
I have a Vu+ Duo 2 and I'm happy of the a/v quality.. but I'm not sure about my sat tuner NIM AVL 2108, I suppose it's not a dual tuner but only a single tuner someone can confirm that the dual sat tuner of the Vu+DUO2 is /or not AVL 2108.
Thank you
Thank you
It's the single tuner. If you look on the tuner (external parte) you can see only one LNB In. The other IF connector is the loopback
