i have found some, skin_user.xml, but after i have replaced the one i have in the box , the box alwas chrashes after reboot, so i have to install the image again, does anyone have any working skin_user.xml? i would like a xml with a bigger Clock than the original.
Editing skin_user.xml (and generally any skin.xml) requires some XML programming skillness, so if you're not enough experienced in this field or don't wish to learn skin coding, there is nothing you can do by yourself.
My only suggestion is to try installing some other skins that possibly fix your problem.
Hi, did you ever find a suitable skin ? I have been looking for one similar, actually only interested in having a clock on it while the box is on. If you did I'd love to know where you got it.
I like your skin because with Duo2 you don't need many infos on the VFD.
Two questions:
1) I see that your skin displays the channel name watching TV and the movie title watching a recorded file. As L4L shows the picon, would be possible to display on VFD the event name instead of channel name?
2) I'm now trying to use 2.1.7 if I solve some problems. There I don't see the skin_user.xml: just skin.xml and skin_default.xml.
The skin_user.xml can be used also in 2.1.7? Does it replace the default in case BH finds it? Or the role of skin_user is taken by one of these two other files in 2.1.7?
Two questions:
1) Test the file attached ( to test ftp it to --> /etc/enigma2
Don´t forget to restart enigma
2) skin_user.xml is at /etc/enigma2 folder ( you haven´t searched the correct folder --> you have searched on /usr/share/enigma2/ ... where are the skins located ), default skin and others installed on your STB.
I´ve tested the skin_user.xml ( ev0 and eragon ), 2 different skins ... and they work flawlessly on BH 2.14, 2.15, 2.1.6 and 2.1.7.
Make a previous copy of the skin_user.xml located where i told /etc/enigma2 to a directory you want on your PC.
With this version attached ... i´ve moded ... ev0 version to display the current event ... you´ll have 4 versions to work with ...
I'm enjoying really much your VFD skin.
3 things:
-which lines should I delete to leave just the title of the event and the event progress bar, without tuners, time and so on?
-I read that there is an option to make text rolling horizontally: is it true?
-what's the line about the event's name to set a smaller size?
I made some changes to the "skin_user.xml" so that is only a big clock and a progressbar in all the menyes. Works great on Blackhole and VU+ Duo2.
Use it as nunigala discribes earlier.
i like this big clock ... but when you put the duo2 in standby mode the clock dissapears , nothing show on the vfd screen..how do i get the clock to still show in standby ? i would also like to make the clock bigger, what do you edit in the skin.user.xml file ? ta
