4.2.2 not supported.Perhaps more a Vu+ hardware question than image, but does anyone know if the Vu+ supports 4.2.2 or can hardware blind scan?
I see there is a software Blindscan in 1.7.6 (which i did use, although manual scan worked better, as the Blindscan missed things)
Thank You![]()
You can stream 4.2.2 to a pc and it will show a picture then (assuming unencrypted feed).4.2.2 not supported.
