Vu+ Immagine Ufficiale v6.0
angelofsky1980
BlackHole Driver Specialist
Vu+ ha rilasciato la immagine ufficiale v6.0 per i suoi box!
Open Embedded
- Add WebBrowser plugin(Duo/Uno, Duo needs a bootloader update)
- Add UI postion control plugin
- Add 3D framebuffer control plugin
- Add remote control system code control plugin
- For details, please take a loot at git log.
Driver update
20111006
- improve DVB-C/T tuning(uno)
- Fix incorrect display of DVB-C/T SNR/AGC(uno)
- Fix high-bitrate problem in CI(uno, needs a FPGA update, New Rev 4.2 FPGA image is at http://archive.vuplus.com/download/fpga/vuuno/4.2/)
- Support 3D framebuffer
- Add interface for UI position setup
- Add redundant fpga device at /dev (uno)
- Add ioctl for hdmi_cec(get physical/logical addr.)
- Fix audo mute in pass-through(uno)
- Add interface to set the system code of the remote control(uno)
- Add interface to disable REC VFD icon(uno,duo)
- Add interface to control global alpha
DUO Boot loader update(duo_cfe_3_0_usb.zip)
- Increase update file size up to 128M Bytes
- Change the flash memory map(kernel size : 4M, /boot : 2M)
* Delete the cfe_cfe_auto.bin at /vuplus/duo in USB after update is complete.
Vu+Uno USB
Vu+Uno NFI
Vu+Duo USB
Vu+Duo NFI
Vu+Solo USB
Vu+Solo NFI
