I have been in possession of the vu + uno 4k BH 3.1.0 for a few days but I have problems with usb tuner xbox it is not detected, in the / lib / firmware folder I can see some dvb-usb-dib0700-01.fw files, so the files should to be install.
the problem is the kernel or is there any fix ?
alternatively, VU + Turbo SE Combo DVB-C / T2 works? can i buy?
These pictures comes from OBH not BH and he says he has BH installed.
@oronero83: what is this VU+ ONE... UNO is not written in Italian because the customise their models for each country
Exactly like Audi QUATTRO is not named so only in Italy's market whilst it is named Audi FOUR in the English speaking countries
sorry i wrong write for distraction not customise
yes correct VU+ UNO 4k
i had tried with other image including OBH but xbox one tuner not works
now work perfect BH 3.1.0 sky digital key af9035 only dvb-t
but i want use usb tuner dvbt-t2 because in my country the future is only dvb-t2
my last test is buy VU+ Turbo SE, if that doesn't work i change decoder
I don't remember how it is in BH but it seems to me that it is still simpler than in OBH, I think you recognize it immediately. Both Uno 4K SE and Uno 4K. I can try on Uno 4K SE but I have to put BH on OMB... I think I only did it on Duo 4K before having MTSIF. As for the purchase of the Turbo SE, maybe, if you can't get the XBox to work, choose the first model ... it's that I've seen reports of problems with the SE.
thanks so much for help
but in BH i see just installed driver dvb-usb-dib0700-01, not work, not detected
i just many tried other image oe-alliance, not work
i thinks the problem is the old kernel 3.14.28 v+ uno 4k is not compatible with the driver, i not attend vu+ updated kernel or not
vu+ uno 4k se kernel 4.1.20 vu+ duo 4k kernel 4.1.45
vu+ uno 4k is my first v+ reciver because for many year i have used dm500hd slow but stable in all, the future in my country is dvb-t2 and h265
i like vu+ hardware , image ..... but for vu+ uno 4k i am disappointed
my solution is return back vu+ uno 4k and buy vu+ uno 4k se
