VU+ player HD for iOs crashes
AlexWilMac
Moderator
As in the subject, I tried for the first time the iOs app VU+ player HD, at first only with the image I'm currently using, OBH 4.1. Each time I used to stream, it caused a crash, 100% of the times.
I thought it was an app's issue but then I tried it with BH 3.0.4E and there it worked perfectly.
Has anyone else any feedback about that?
I'm planning to try this app also with other two images installed in OMB. I'll refer about this tries as soon as I'll do it.
Use En2Player
en2Player di Robert Knaufhttps://itunes.apple.com/it/app/en2player/id956118762?mt=8
Nice app! Thanks! Much better than the standard VU+ player and it doesn't crash under OBH 4.1.
What's really odd is that it shows only some picons. Maybe some are too large for it...
I hoped it existed also for Android, to install to a guest of mine, but it seems it's only for iOs. D'you know if there is anything similar for Android? VU+ Player HD for Android doesn't cause any crash with OBH 4.1 but it's quite uncomfortable.
