Vu + Player
andyros
Hello, I have installed black hole firmware 3.0.3 G and I do not connect the application android vu + player, I tried with open black hole and openspa and if they work, but I would like it to work with black hole 3.0.3 G, to see If you know how to make it work.
A GREETING.
Same problem with me. Changed from openpli to BH 3.0.3 P and can't connect using Vu+PlayerHD on android. I could previously. It can see receiver IP, but it is not active (no green button). When I press save it shows Connection Failed. Openwebif is activated and I can stream video from receiver on PC. I have Vu+Duo2. BH 3.0.3.P and skin MX HQ10. Can anybody help ?
Same here since I migrated from 2.1.7 to 3.x, the android app does not work anymore .....
