Vu plus duo not booting
kirupa29
Hi..pls help anyone... My vu plus duo box not booting up aftwer installed the images.. Nothing come after booting just spinning nothing come afterwards. I done boot loader as well
which image you try to install ? please check if your box is genuine or not...
Thanks for ur reply
Vu plus duo box... I used before with image 1.7.1 blackhole.. Suddlenly stop it then I restat it .. Screen is coming but its not booting afterwards.. Just spinning ....Then I tried to reflashed it still have same problem..
Thanks for ur reply
are you sure that your box is original? try to update another time the bootloader and then reflash with one of the last bh images. if is not working :confused: it can be a clone...
Thanks for ur reply
When you restart the box, there is only the red led turned on?
Thanks for ur reply..
Box is original I using 9 month now.. When I on the box.. Its starting then say vu +duo.. On the receiver ..nothing coming after wards. When I press the remote buttons just come red light flash it.. On the TV screen just saying starting Gul .. And spinning sign on the corner
Red light is not display on the vue.. After strat up
