Vu+ SE v1 problem - please help
Hello
I have had the Vu+ SE v1 for around 4 months and have a recurring problem which is very annoying . I have connected to the unit a 500 gb usb hardisk and the usb VU+ turbo tuner .
I use the VU+ SE to watch satellite channels with internal tuner, the Turbo to watch Digital terrestrial tv channels. I am using your latest image . When I open the unit everything works fine. I can watch any terrestrial channel and any sat channel without any problem , I can switch between them without any issue . Now if I watch a satellite channel for a average amount of time lets say 1 hour and try to switch to a terrestrial channel the unit gets stuck and needs a hard reboot by power switch . This never happens when switching from terrestrial channel to sat channel. I am not a complete novice but for the life of me have no idea how to fix this or how to report it correctly so someone can help me. I have tried to fix it by installing other images and my results are the following :
1.open blackhole image - everything works but sat tuner to terrestrial tuner switch needs hard reboot as described above
2. openvix image - everything works but sat tuner to terrestrial tuner switch needs hard reboot as described above
3. blackhole image -turbo tuner is recognized but can not mount usb hardisk
4. VTI image - turbo tuner is recognized but can not mount usb hardisk
Any help will be appreciated
Hello
