VU+ Solo 2
WebMan
Hi everyone.
Today I setup my new VU+ Solo 2 with BlackHole 1.7.9.-3 (latest I found) and I found a problem (bug?).
On receiver display I can't see nothing, only symbol of HD, without channel name.
If I use Setting/Configuration, on display appear the name of the area were I'm in, and, when I finish and I turn to the channel, the name remain there this I go in other menu or settings...
There is something I can do ?
Thx in advance....
Ciao a tutti.
Oggi ho impostato il mio nuovo VU + Solo 2 con l'immagine BlackHole 1.7.9.-3 (l'ultima che ho trovato) e ho trovato un problema (bug?).
Sul display del ricevitore non riesco a vedere nulla, l'unica cosa è il simbolo di HD, senza il nome del canale.
Se uso Impostazione / configurazione, sul display appare il nome della zona dove mi trovo, e, quando ho finito e ritorno al canale, il nome rimane finché non vado nel menu delle impostazioni o altro ...
C'è qualcosa che posso fare?
Grazie in anticipo ....
Try to reflash with an original image (not your backup) and don't do any online update, it could be a bug.
Hi everyone.
Thx in advance....
Ciao a tutti.
It may be a skin issue.
If you are using another skin, try to use the default one.
#paolino - I use the original image (decoder brand new), without updates on-line... After that I put ***** *** (ipk)
#Mito - It's original skin, I don't use any other skin....
Follow Paolino advice and read our board rules (exactly point 4).
Sorry 'bout that....​
It's only for study... :)
I have read the rule...​
I have the same rules on my forum (RDI Board), so I'm really sorry...​
Yes, I install LCD Picons...
If I delete the directory is OK or I must uninstall them ?
LATER Edit:
I delete all picons (I let only the default one) and I restart the receiver...
LATER Later Edi:
Nothing happen.... same "black screen"....
OK, it's better to delete all, without making any backup...
Then install BH 1.7.9-3 and control if the display work, wright ?
How can I format the memory ?
Using the HARD RESET or just boot with USB stick and install the image ?
No, if you only have problem with LCD you can remove LCD picons
YOU must Remove skin_user.xml file and restart.
