VU+ Solo Auto Power on
ygaroyian
I bought VU+ Solo and what i noticed is that it automatically turns on when i plug in the power cord. Is it possible to disable auto power on when the unit is plugged in?
It is really annoying cause i have Logitech harmony remote control and it messes up everything :(
Thank you
Thank you
Instead to disconnect the power cord after the usage of the box, put it into standby.
Solo starup automatically when you plug the power cord.
Does it start and load firmware also if, before, you did a "deep standby" (shutdown) the box? I owned a SOLO, but don't remember now if it remember last state (i now have a ZERO which has a power button on the rear side).
Anyway, you can also try the plugin "enigma2-plugin-extensions-startuptostandby" which make standby of stb when Enigma2 is loaded.
Hello, I try plugin "enigma2-plugin-extensions-startuptostandby" - its he same result: tuner wakes up after a power off from him. Maybe you know another way to solve this problem or use another plugin?
Thanks
Problem is: I try install plugin "enigma2-plugin-extensions-startuptostandby" - result: tuner wakes up after a power ON & automatically turns on the power of the TV (This is very disturbing, especially at night when electricity is lost for a short time) Maybe you know another way to solve this problem or use another plugin? Thanks
