Vu+ Solo bloccato
Siz72
Ciao a tutti,
ho comprato da poco un Vu+ Solo. Acceso, funziona tutto.
Dopo neanche 24 ore vedo schermo nero e il decoder non risponde al telecomando (lampeggia il led, ma, per esempio, lo standby non fa diventare rosso il led come prima).
I led sull'uscita della rete sono spenti.
Collegato alla seriale, accendo e l'output è il seguente
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF4
RC2=00000018
WC2=00000021
RC3=0000000E
WC3=FFFFFFF4
RC4=0000000E
WC4=0000003D
NWC=00000018
RC5=00000005
WC5=00000018
RC6=00000018
WC6=00000018
NRC=0000000E
RW=00000014
WW=0000004A
G=00000000 R=0000000E W=00000018
BL=00000000
RC1=00000006
RC2=0000001A
BL=00000001
RC1=00000004
RC2=00000018
BL=00000002
RC1=00000003
RC2=0000001B
BL=00000003
RC1=00000000
RC2=00000017
3
COPY CODE
AS567
CP16=80040483,BEA3519F,80000167
BCM97325B0 CFE v2.27, CFE core v2.12, Endian Mode: Little
Build Date: Wed May 18 10:18:50    2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
DDR Freq:      398MHz
CPU speed:    333MHz
Memory Config: 32-bit UMA
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
checking usb
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000
Loading: 0x80001000/6474084 0x8062d964/115692 Entry address is 0x804d2540
Starting program at 0x804d2540
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1 Sun Feb 5 10:18:06 CET 2012
Fetching vars from bootloader... found 7 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=0 enet=1 emac_1=0 no_mdio=0 docsis=0 pci=1 smp=0 moca=0 usb=1
Using 256 MB RAM (from straps)
bootconsole [early0] enabled
CPU revision is: 0101954c (Brcm4380)
FPU revision is: 01739300
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 144 MB RESERVED region at 112 MB (0x09000000@0x07000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  Normal  0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
MIPS secondary cache 128kB, 8-way, linesize 128 bytes.
Writing ErrCtl register=00800000
Readback ErrCtl register=00800000
L2 cache parity protection enabled
Memory: 105956k/262144k available (4976k kernel code, 156188k reserved, 1128k data, 216k init, 0k highmem)
NR_IRQS:128
Detected MIPS clock frequency: 332 MHz (166.499 MHz counter)
Calibrating delay loop... 220.16 BogoMIPS (lpj=110080)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 206
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
loop: module loaded
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:02:55:16)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 63, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 64, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 59, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0200 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.0 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007400000 : "rootfs"
0x000007400000-0x000007800000 : "kernel"
0x000007800000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:      433
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            116 MiB
UBI: number of good PEBs:        924
UBI: number of bad PEBs:        4
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 924
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 3/0
UBI: image sequence number:  1452538043
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 36
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  114278400 bytes (111600 KiB, 108 MiB, 900 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 216k freed
se collego a questo punto una chiave usb, vedo che la riconosce (sempre sulla console), ma sul video non appare nulla. Ho provato scart, RCA e HDMI.
L'avrei già riportato a controllare a chi me l'ha venduto, ma è chiuso per ferie.
Magari chiedendo è una cavolata e risolvo al volo.
Accetto suggerimenti
Ciao a tutti,
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000005
WC1=FFFFFFF4
RC2=00000018
WC2=00000021
RC3=0000000E
WC3=FFFFFFF4
RC4=0000000E
WC4=0000003D
NWC=00000018
RC5=00000005
WC5=00000018
RC6=00000018
WC6=00000018
NRC=0000000E
RW=00000014
WW=0000004A
BL=00000000
RC1=00000006
RC2=0000001A
BL=00000001
RC1=00000004
RC2=00000018
BL=00000002
RC1=00000003
RC2=0000001B
BL=00000003
RC1=00000000
RC2=00000017
3
COPY CODE
AS567
DDR Freq:      398MHz
CPU speed:    333MHz
Device Tech:  1Gb
Total memory:  256MB
Total flash:  128MB
Initializing USB.
CFE initialized.
checking usb
Zone PFN ranges:
NR_IRQS:128
TCP reno registered
loop: module loaded
ALSA device list:
UBIFS: parse sync
Non ricordo che data riporta il CFE aggiornato per il Solo, ma ti consiglio vivamente di aggiornare tale componente software, riflashare l'immagine che ti aggrada ... e vedere se le cose cambiano.
avete risolto?? ho lo stesso problema cosa devo fare, ho provato e riprovato sia cfe che immagini anche la 1.7.2 e 1.7.5, led sempre verde e i segnali del telecomando li riceve ma nn fa niente, provato sia scart che hdmi
Cioè ti compare a video l'immagine del logo dell'immagine ma non puoi far nulla con il telecomando... oppure schermo nero e led verde?
la seconda ho provato anche immagini più vecchie, ma niente, led sempre verde e schermo nero, sembra ricevere i comandi del telecomando visto che lampeggia il led verde ma nn fanno nulla ne standby ne cambia nienteee
Servirebbe un output dalla porta seriale per capire che cavolo succede al tuo box .....
Intanto servirebbe sapere che colore sono i led, in fase di flash ...
allora ho un vecchio computer con la porta seriale, sto usando hyperterminal ma cosa devo mettere nelle impostazioni della porta??
ok alla fine mi da kernel panic , not syncing e rebooting in 180 seconds
Infatti dopo 3 min si riavvia senza cambiar niente,ho provato a mettere i file dalla chiavetta , con la porta seriale inserita, ma al riavvio niente sempre kernel panic.
Ho provato anche vu utility ma al 40 % quando scrive per l'appunto il file del kernel da errore e si blocca, cosa faccio?????
Puoi postare l'output della operazione di flash?
E comunque non mi hai risposto sui led: di che colore sono?
l'operazione di flash quale dell'immagine o del cfe.. e poi non capisco in che senso il colore dei led..sarebebro rosso arancio e verde
DDR Freq: 398MHz
CPU speed: 333MHz
Device Tech: 1Gb
Total memory: 256MB
Total flash: 128MB
Initializing USB.
CFE initialized.
USB: New device connected to bus 1 hub 1 port 1
USB: Resetting device on bus 1 port 1
USB: Locating Class 08 Vendor 0951 Product 1607: Mass-Storage Device
USBMASS: Unit 0 connected
checking usb
Reading usbdisk0:/vuplus/solo/cfe_cfe_auto.bin: >> Skipping...: File not found
Reading usbdisk0:/vuplus/solo/root_cfe_auto.jffs2: >> Done. 65404928 bytes read
nand_erase_block 0x18f20000 0x20000 done
nand_erase_block skipping: at blk addr = 0x18f20000
nand_erase_block 0x1a020000 0x20000 done
nand_erase_block skipping: at blk addr = 0x1a020000
Programming...
done. 65404928 bytes written0x20000 done
Reading usbdisk0:/vuplus/solo/boot_cfe_auto.jffs2: >> Done. 576 bytes read
Programming...
done. 576 bytes written0000 0x20000 done
Reading usbdisk0:/vuplus/solo/kernel_cfe_auto.bin: >> Done. 3421256 bytes read
Programming...
done. 3421256 bytes written 0x20000 done
please remove usb first and reboot
DDR Freq: 398MHz
CPU speed: 333MHz
Device Tech: 1Gb
Total memory: 256MB
Total flash: 128MB
Initializing USB.
CFE initialized.
checking usb
Programming...
Programming...
Programming...
Il log è chiaro... ha finito di flashare, rimuovi la pennetta USB e reboota.... magari posta anche il log del primo reboot ....
se fosse stato così facile, al reboot alla fine mi da
Kernel panic - not syncing: Fatal exception in interrupt
<0>Rebooting in 180 seconds..
