hi all
this is my first post ever on any satelit forum, i got this vu+ solo clone box. no matter what image i install screen goes black after a few minut, maybe 10-20min at maximun... i hade solo box, solo uno, dm800 and i have allways found a way out of any of my problem with any of those boxes. but this one makes me Crazy :-(
and i can´t understand the crash log, so i hope you guys can help
Here is the crash log:
<?xml version="1.0" encoding="utf-8"?>
<openvix>
<enigma2>
<crashdate>lør aug 16 23:03:10 2014</crashdate>
<compiledate>Oct 16 2013</compiledate>
<contactemail>vixlogs@world-of-satellite.com</contactemail>
<skin>ViX-Night-HD/skin.xml</skin>
<sourcedate>2013-10-16</sourcedate>
<version>3.0.0</version>
</enigma2>
<image>
<stbmodel>solo</stbmodel>
<kernelversion>
<!-- Cannot allocate memory -->
</kernelversion>
<kernelcmdline>bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw console=ttyS0,115200n8 rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
box_type=vusolo
build_type=0
version=3.0
build=753
drivers=20130904
date=20131016111016
comment=ViX
target=9
creator=openViX
url=http://www.vuplus-support.co.uk
catalog=http://www.vuplus-support.co.uk
</imageversion>
<imageissue>
<![CDATA[
Welcome to OpenViX for %h
openvix 3.0 %h
</imageissue>
</image>
<software>
<enigma2software>
</enigma2software>
<vuplussoftware>
</vuplussoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
+ (1) Background File Eraser
+ (5) Tuxtxt
+ (8) graphics acceleration manager
+ (9) GFBDC
10800k video mem
- double buffering available!
3600kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 5120)
+ (9) gLCDDC
found OLED display!
lcd buffer 0x810808 8448 bytes, stride 132
LCD resolution: 132 x 64 x 8 (stride: 132)
+ (9) Font Render Class
[FONT] initializing lib...
[FONT] loading fonts...
[FONT] Intializing font cache, using max. 4MB...
+ (10) gRC
RC thread created successfully
+ (15) eWindowStyleManager
+ (20) DVB-CI UI
+ (20) UHF Modulator
couldnt open /dev/rfmod0!!!!
+ (20) RC Input layer
+ (20) misc options
+ (20) AVSwitch Driver
couldnt open /dev/dbox/fp0 to monitor vcr scart slow blanking changed!
+ (21) input device driver
Input device "dreambox advanced remote control (native)" is a mouse
Found 1 input devices.
+ (22) Hdmi CEC driver
+ (30) eActionMap
+ (35) CI Slots
scanning for common interfaces..
CI Slot 0 setSource(0)
CI Slot 1 setSource(0)
eDVBCIInterfaces->setInputSource(0, 0)
eDVBCIInterfaces->setInputSource(1, 1)
cannot open /proc/stb/tsmux/input2
cannot open /proc/stb/tsmux/input3
done, found 2 common interface slots
+ (35) CA handler
+ (36) Stream server
+ (40) eServiceCenter
settings instance.
+ (41) eServiceFactoryDVD
+ (41) eServiceFactoryM2TS
+ (41) eServiceFactoryMP3
+ (41) eServiceFactoryFS
+ (41) eServiceFactoryDVB
reached rl 70
---- opening lame channel db
reading services (version 4)
loaded 0 services
scanning for frontends..
opening frontend 0
close frontend 0
found 1 adapter, 1 frontends(1 sim) and 5 demux, boxtype 2
Use valid Linux Time (RTC?)
[EPGC] Initialized EPGCache (wait for setCacheFile call now)
Loading spinners...
[ePNG] couldn't open /usr/share/enigma2/spinner/wait20.png
found 19 spinner!
setIoPrio best-effort level 3 ok
Failed to open /dev/dbox/fp0
[Harddisk] enumerating block devices...
[Harddisk] enumerating network mounts...
main thread is non-idle! display spinner!
Reading satellites.xml
sec config cleared
setSlotInfo for dvb frontend 0 to slotid 0, descr BCM7325 DVB-S2 NIM (internal), need rotorworkaround No, enabled Yes, DVB-S2 Yes
slot: 0 configmode: simple
diseqcmode: diseqc_a_b
sec config completed
[Time By]: Transponder
[Ipkg] Added to OPKG destinations: /
[FONT] adding font /usr/share/fonts/Roboto-Bold.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/Roboto-BoldItalic.ttf...OK (Italic)
[FONT] adding font /usr/share/fonts/Roboto-Black.ttf...OK (Bold)
[FONT] adding font /usr/share/fonts/Roboto-BlackItalic.ttf...OK (Boldit)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Subtitlefont)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[SKIN] loading include: /usr/share/enigma2/ViX-Common/CommonSkin.xml
[FONT] adding font /usr/share/fonts/valis_enigma.ttf...OK (Subs)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (FdLcD)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
Activating keymap: Default (US)
Activating language Dansk
cannot open /proc/stb/avs/0/input_choices
--> setting scaler_sharpness to: 0000000D
[EPGC Load] Poller disabled.
[EPGC Save] Poller disabled.
[EPGC] setCacheFile read/write epg data from/to '/etc/enigma2/epg.dat'
[EPGC] time updated.. start EPG Mainloop
couldn't open /proc/stb/misc/12V_output
[EPGC] /etc/enigma2/epg.dat not found, try /epg.dat
Setting OSD position: 0 720 0 576
Setting OSD alpha: 255
Setting 3D mode: auto
Setting 3D depth: 50
FIXME: request for unknown slot
[GP2FlashBackup] found LANGUAGE= da
[GP2FlashBackup] fallback to default translation for Choose backup location
[GP2FlashBackup] fallback to default translation for GP2 FlashBackup
[GP2FlashBackup] fallback to default translation for 1:1 Flashimage-Backup on HDD, CF, SD, USB or Networkmount
Plugin Extensions/WebInterface failed to load: No module named plugin
getModeList for port DVI-PC
getModeList for port Scart-YPbPr
getModeList for port YPbPr
hotplug on dvi
-> setting aspect: 16:9
-> setting wss: auto
-> setting policy: pillarbox
-> setting policy2: letterbox
setMode - port: DVI mode: 1080i rate: multi
[XMLTVImport] autostart (0) occured at 1408226420.45
[AutoTimer] Auto Poll Enabled
[SoftcamManager] AutoStart Enabled
[CI_Assignment] activating ci configs:
[CI_Activate] FOUND 2 CI Slots
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
[CI_Activate_Config_CI1] no config file found
[CI_Activate_Config_CI1] error parsing xml...
starting hotplug handler
[ImageManager] AutoStart Enabled
[ImageManager] Backup Schedule Disabled at (now=lør 16 aug 2014 23:00:20 IST)
[BackupManager] AutoStart Enabled
[BackupManager] Backup Schedule Disabled at (now=lør 16 aug 2014 23:00:20 IST)
[AutoBouquetsMaker] AutoStart Enabled
[AutoBouquetsMaker] AutoBouquetsMaker Schedule Disabled at lør 16 aug 2014 23:00:20 IST
[XMLTVImport] autostart (0) occured at 1408226420.56
[XMLTVImport] WakeUpTime now set to -1 (now=1408226420)
warning, skin is missing element state in <class 'Screens.PVRState.TimeshiftState'>
RemovePopup, id = ZapError
[Skin] Attribute not implemented: alphatest value: blend
setValue 100
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
[LogManager] Trim Poll Started
[LogManager] Trash Poll Started
child has terminated
pipes closed
pipes closed
poll: unhandled POLLERR/HUP/NVAL for fd 32(16)
poll: unhandled POLLERR/HUP/NVAL for fd 36(16)
job Components.Task.Job name=LogManager #tasks=1 completed with [] in None
[LogManager] probing folders
[LogManager] found following log's: ['/home/root/logs']
[LogManager] looking in: /home/root/logs
pipes closed
0.0.0.0
192.168
ER plugin not found
[OpenWebif] loading external plugins...
[OpenWebif] no plugins to load
[OpenWebif] started on 80
[OpenWebif] started on 443
executing opkg --add-dest /:/ update
job Components.Task.Job name=OnlineVersionCheck #tasks=1 completed with [] in None
pipes closed
executing opkg --add-dest /:/ list-upgradable
job Components.Task.Job name=SoftcamCheck #tasks=1 completed with [] in None
pipes closed
[OnlineVersionCheck] 27 Updates available
[OpenWebif] page '/web/session' not found
loaded 1303 services
[OpenWebif] page '/web/servicelistreload?mode=0' ok (cheetah template)
KEY: 402 BOUQUET+
action -> InfobarChannelSelection ChannelPlusPressed
playing 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
no .meta file found, trying to find PMT pid
file not valid
alloc PVR
allocate demux
PVR source is not valid!
[Picload] setPara max-X=100 max-Y=60 aspect_ratio=0.000000 cache=1 resize=1 bg=#FF000000
[Picload] decode picture... /usr/share/enigma2/ViX-Night-HD/picon_default.png
eDVBServicePlay::unpause
KEY: 402 BOUQUET+
KEY: 401 BLUE
KEY: 401 BLUE
action -> InfobarExtensions extensions
KEY: 174 EXIT
action -> WizardActions back
KEY: 174 EXIT
KEY: 103 UP
action -> InfobarChannelSelection switchChannelUp
KEY: 103 UP
KEY: 401 BLUE
action -> ChannelSelectBaseActions showFavourites
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 352 OK
action -> OkCancelActions ok
KEY: 352 OK
action -> OkCancelActions OK
unknown action OkCancelActions/OK! typo in keymap?
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 398 RED
action -> ChannelSelectBaseActions showAllServices
KEY: 398 RED
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 352 OK
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
playing 4097:0:0:0:0:0:0:0:0:0:http%3a//viasatlive2-i.akamaihd.net/hls/live/202775/tv3plus/mastererki1.m3u8:TV3+ HD
getResolvedKey config.mediaplayer.useAlternateUserAgent failed !! (Typo??)
getResolvedKey config.mediaplayer.extraHeaders failed !! (Typo??)
getBouquet failed.. no path given!
KEY: 352 OK
eServiceMP3::state transition NULL -> READY
!!!!!!!!!!!!!!!bufferfull
!!!!!!!!!!!!!!!!!!!!!!!!VideoChanged
REF: 4097:0:0:0:0:0:0:0:0:0:http%3a//viasatlive2-i.akamaihd.net/hls/live/202775/tv3plus/mastererki1.m3u8:TV3+ HD
REF: True
TEST 1: 200
!!!!!!!!!!!!!!!!!!!!!!!!VideoChangeDetect
config mode: 1080i
config res: 1080
config rate: multi
config pol: i
current aspect: 16:9
current mode: 720p50
current pol: p
current res: 720
current rate: 50
CURRENT MODE: 720p50
NEW MODE: 1080i
aspect: 16:9
REF: True
TEST 1: 200
config mode: 1080i
config res: 1080
config rate: multi
config pol: i
current pol: p
current res: 720
current rate: 50
NEW MODE: 1080i
CHANGE MODE
[AutoRes] changing to 1080i
aspect: 16:9
KEY: 139 MENU
action -> InfobarMenuActions mainMenu
[***GP2 FlashBackup***] - flashbackup main start
KEY: 139 MENU
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
action -> OkCancelActions cancel
KEY: 174 EXIT
eServiceMP3::http source timeout! issuing eof...
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
action -> ColorActions blue
unknown action ColorActions/blue! typo in keymap?
KEY: 108 DOWN
action -> WizardActions down
unknown action WizardActions/down! typo in keymap?
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
action -> WizardActions ok
unknown action WizardActions/ok! typo in keymap?
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 103 UP
action -> WizardActions up
unknown action WizardActions/up! typo in keymap?
KEY: 103 UP
KEY: 352 OK
[SKIN] No skin to read...
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 402 BOUQUET+
ignore request to play already running service(1)
KEY: 402 BOUQUET+
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
KEY: 352 OK
KEY: 103 UP
KEY: 103 UP
KEY: 398 RED
KEY: 398 RED
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
playing 1:0:1:1B68:42:46:E080000:0:0:0:
eServiceMP3::stop http://viasatlive2-i.akamaihd.net/hls/live/202775/tv3plus/mastererki1.m3u8
PC: 76fc7728
00000000 00000001 01b246b0 00000001
00000000 00000001 00000001 00000000
00000000 00000001 8009876c fffffff0
77008000 766d7020 00000000 00000000
00000004 00000000 00000008 00000000
01b246b0 76f9e390 72a6f814 72a6f284
00000000 76fc76f0 00000001 00000000
7700bbc0 71a5eca8 770e6328 72a6b264
</enigma2crashlog>
</crashlogs>
</openvix>
<openvix>
<enigma2>
</enigma2>
<image>
<kernelversion>
</kernelversion>
<imageversion>
<![CDATA[
box_type=vusolo
build_type=0
version=3.0
build=753
drivers=20130904
date=20131016111016
comment=ViX
target=9
creator=openViX
</imageversion>
<imageissue>
<![CDATA[
openvix 3.0 %h
</imageissue>
</image>
<software>
<enigma2software>
</enigma2software>
<vuplussoftware>
</vuplussoftware>
<gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
+ (5) Tuxtxt
+ (9) GFBDC
10800k video mem
+ (9) gLCDDC
found OLED display!
+ (10) gRC
+ (20) DVB-CI UI
+ (20) misc options
+ (30) eActionMap
+ (35) CI Slots
+ (35) CA handler
settings instance.
reached rl 70
loaded 0 services
opening frontend 0
close frontend 0
Loading spinners...
found 19 spinner!
sec config cleared
hotplug on dvi
setValue 100
pipes closed
pipes closed
pipes closed
0.0.0.0
192.168
ER plugin not found
pipes closed
pipes closed
KEY: 402 BOUQUET+
file not valid
alloc PVR
allocate demux
KEY: 402 BOUQUET+
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 103 UP
KEY: 103 UP
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 352 OK
KEY: 352 OK
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 398 RED
KEY: 398 RED
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 352 OK
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
REF: True
TEST 1: 200
config mode: 1080i
config res: 1080
config rate: multi
config pol: i
current pol: p
current res: 720
current rate: 50
NEW MODE: 1080i
aspect: 16:9
REF: True
TEST 1: 200
config mode: 1080i
config res: 1080
config rate: multi
config pol: i
current pol: p
current res: 720
current rate: 50
NEW MODE: 1080i
CHANGE MODE
aspect: 16:9
KEY: 139 MENU
KEY: 139 MENU
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 401 BLUE
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
KEY: 352 OK
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 174 EXIT
KEY: 402 BOUQUET+
KEY: 402 BOUQUET+
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
KEY: 352 OK
KEY: 103 UP
KEY: 103 UP
KEY: 398 RED
KEY: 398 RED
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 105 LEFT
KEY: 106 RIGHT
KEY: 106 RIGHT
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 108 DOWN
KEY: 103 UP
KEY: 103 UP
KEY: 352 OK
PC: 76fc7728
</enigma2crashlog>
</crashlogs>
</openvix>
