do i have to flash it via USB? i never did it
i had BH 162, i will try tp put 164, i'm not sure it works good,
don't u think it's meoboot? how can i cancell meoboot?
np about it, just flash the box using the usb flash drive, quite simple and fast
and maybe better with the latest image you like (but no someone else backups)
you know what, without flashing it, i pluged off the LAN cable, and the device restarted normally
i think the problem is that the device is trying to download something from the net while BOOTING
