bo1e
I am trying to add a harddisk to my Vu+ Solo, but not having much luck. I have tried two different harddisks with the same results. The problem is that every time I restart the solo, the harddisk reports -1 mb free, and has to be initialized before I can use it. I have the disk connected via an internal usb hub. I have tried connecting it to the rear usb port, but it makes no difference.
At first I tried with no additional power, other than connecting the usb hub to the 5V on the power supply inside the box. Everything seemed to work, except it sounded like the harddisk had some problems when powering up, it went on and off a few times before spinning up completely. Other than that it worked fine after initializing it. But after restarting the solo, the disk reports -1 mb free, and has to be initialized again. So I thought maybe it needed more power. I've read several places that the disk has to have external power, I guess the 5V usb power in the box is not enough?
Now I have the usb hub connected to the 220V inside the box, thru a 5V dc 1200 mA converter. That should be enough power. It no longer seems to struggle when it powers up. Still works fine after initializing. But still reports -1 mb free and need initializing after every restart. What am I doing wrong here? Has anyone else had this problem? Does this happen to anyone else?
