denon54
Hello,
i would like some advice about the configuration of a hard disk on a vu+solo.
i installed a hard disk on the rear usb , i format it and mount it inside BH 1.7.2.
i also configured the stand on 20' and the problem is that the HD never stop spinnning!
when i put the receiver in stand by by the red button above the remote control, i wait for 20
minutes and even then after the hd is still spinning.
Ithe try to disable the craslog report in the system menu settings but doensn't work either.
Iknow that we don't have such a issue with a vu+duo,uno and ultimo because they use a sata
disk inside, but for people like me that use a solo with a external usb hard-disk it is a problem.
if you have any idea it should be great.
thank you..
denon54
thank you..
denon54
