This is almost the same issue of the thread vu duo dead After reading it throughly i wanted to share the issue of by box.The thread title suggest that the box seems to somwhat better than compeletely dead.
here when i plugin the mains its normal green light.But there is no video on the tv,and no remote commands are working tough light blinks when any key is pressed.
And for a surprise even flash ,CFE is updated normally
History
The box was working finde before lightning struk and power fluctuated ,This i can confirm as TV,PC and vu solo are not working after that lighting
After completely reading the vu duo dead thread and other metereal it suggested that to replace C807 Capacitor. Here in vu solo the hybrid capcitor is embedded on mainboard which requires a skilled person to replace it where as in duo its normal capacitor. Apart from it there is no value dispalayed on the capacitor.
Any how will try my level best as i feel there is a normal capacitor 47uf/400v on the power board which seems to be swollen go.I hope it gives life to the box.
Please advise
History
.After completely reading the vu duo dead thread and other metereal it suggested that to replace C807 Capacitor. Here in vu solo the hybrid capcitor is embedded on mainboard which requires a skilled person to replace it where as in duo its normal capacitor. Apart from it there is no value dispalayed on the capacitor.
Please advise
.Any how replaced the capacitor but no results.Any how the lighting killed 3 Motherboards PC,TV & hopefully vu solo because if there was a fault in PSU the box,TV& PC would not have started.
