VU+ Solo - Internal cardreader problem
trax020
Hi,
I tried a viacces card on my father's vu+ solo, and worked perfect. But on mine, it doesn't work, even if I'm using the same settings. I'm using latest blackhole image. Didn't try other images. Could it be a matter of the firmware of the reader? If so is it possibleto upgrade it?
I'm not talking about cam or emu. It seems like a hardware problem with the internal reader. Is there anything to do to fix this?
Any Image for Vu+ boxes supports natively Conax CAS.
Other CAS are not supported.
You can try to test your readers with another card. If doesen't work again, you need a replacement.
my sky box no have HD
my VU+Duo have HD
and like to know do you no oficial card like NDS work and no burn in slots
thx
