Vu Solo is not able to flash
mardoka
Hi,
I used wrong flash file (duo_cfe_3_0_usb) for my VU+ SOLO. Now I not able to use correct reflash cfe_solo_2.0.zip. My VU+ SOLO not able to read USB during start. Have a some idea?
Thanks.
Hi,
Thanks.
Hello
Since you have used a duo bootloader flash on a solo I'm sure there is nothing you can do about it, think you may need to buy a new box I'm afraid
Maybe someone in the community can confirm this please?
Hi,
Thanks.
Other members have answered to your question.
You have tried the CFE bootloader on Solo box and you have bricked them. JTAG or contact your seller for replacement.
Thx for answer. May I "reset or set" on mainboard with some pin. Something like as if is it a new in factory :-). Example start communication via some interface.
Thx for answer. May I "reset or set" on mainboard with some pin. Something like as if is it a new in factory :). Example start communication via some interface.
There are some experimental studies on the web to recover bad flashed boxes like your via JTAG but I've not yet tested it
