Dachtus
Hi to all of you!
I have 2 years now my Vu+ Solo STB and i am facing all this time the same problem...
I decided now to search for a solution and i need your help guys!
The problem occurs ONLY at Sky IT channels and appears a breaking up at the picture of them (like pixelation)... More specific, this pixelation continuous from 0.5 to 1.5 second and appears 2-10 times per minute… I have also to notice that there are days that this phenomenon is less founded and there are days that occurs at it’s maximum frequency (10 times per minute)… You can understand how frustrating and annoying is this when you want so much to watch your favorite channel or show….
I have to notice that this particular problem occurs mostly at HD channels, not so often to SD ones (this doesn't means that it is not happening, as well)...
It is strange because I have NO problem to any of the rest channels or providers, both at 13o and 19,2o , both at HD or SD channels, with bad or good outside weather conditions…
I have an 1m. dish (Gibertini) with 2 LNB’s (13o+19,2o), new cable, SNR 70-76% (for Sky IT), AGC 60% and BER 0 (all these information are given before any of you asks me or propose to me that this problem may occur from bad equipment)…
Well… a friend of mine told me that this is a common problem for Vu+ STBs (moreover for Solo that is weaker than Duo-Ultimate) and it is related to all sr 29900 channels of the Sky IT…
Is there any idea how can I overcome this problem guys?
