hi
dear sirs
i purchased a vu+ solo receiver recently & faced a problem on first week!!
actually, when i was exploring the setup, i entered the "plugins" & downloaded one of the skins in "tunisia...." (which was part of plugin browser in default); after the completion of download i entered the "skin" menu & select it, the system restarted but after booting process the display goes green & gives an error that "..your STB encountered a software problem and needs to be restarted.." and system restarts but the same thing happens again & the unit is not starting!
i thought maybe the selected skin is not compatible with my device, i used the "reset" button on back of receiver but problem still presists.
please guide me how to solve the problem, is there any options that i can use to make the
system goes to "reset to default factory conditions" without using the remote control (because in present conditions the receiver is not responding to the remote control)
please help me, awaitin reply, thanks alot
dear sirs
