Solo vu+solo red light fix
Hello, I have the same problem but now it seems that not even the red light is on. I changed the capacitors and nothing happened.....do I need to change all capacitors or can it be that the transformer is also faulty?
It's funny: this is not a software issue but a hardware failure. Here we can give some generic advices but how can we know if your power supply is defective or anything else needs to be changed? You need a good HUMAN electronic technician.
hello,
Got original genuine VU + Solo witch red light problem,
the PSU got good readings - 12V, 5,3V 3,3V. i changed capacitors in psu and on the mainboard, thought it can be the same problem as in vu+DUO, but all of them was good problem with red light is still. I have reading on the coils near FR9888 IC L1 - 1,24V. L2 - 1,25V, L3 - 2,6V, L3 3,37V is anyone who could help me are these voltages ok or not?
and what are parameters for capacitor c19
what can i check more?
best regards MJ
