VU+ solo se no sound on Setanta HD
Ufopufo
Hi,
I've no sound on one channel (Setanta HD).
Every other channel works well. The picture on Setanta HD is jittering for the first minute,after that the picture gets perfect - no jitter, no blocking. It's just no sound on any audio channels. Used other receiver, and it works there perfectly well. Channel settings (Frequency, symbol rate, modulation) are the same. Signal-Noise-Ratio is 65% on all channels. If the signal could be to low, there would be bad picture I presume. But the picture after 1 minute is perfectly clear.
Its cable channel 65 (826.0M); Symbol rate: 6956 Ks/s; Modulation: QAM256.
Tuner: Vuplus DVB-C NIM(CXD1978) (DVB-C)
Any ideas?
AFAIK Setanta HD is a subscription based Irish sports channel.
No support in this community to encrypted channel decoding and relevant problems.
Should Setanta HD be a free channel please let us know.
