VU+ Solo SE V2 CI Problem
MrMxyzptlk
Hi!
I have a problem with my CI module. I have a Conax Modul with a 0B1D card and a 0B02 card the STB isn't reading correctly my 0B1D card throug my module. My 0B02 is working perfectly more or less (it does not decode 1 channel from my subscription for some strange reason, in rest is OK). But I need to work with the 0b1d card in the module ... I have tried the BlackHole Image (and currently sticking with it) but with some other images as well. In the BlackHole image if I do an init 2 and enigma2 commands it dosn't say anything important but with another image it tells me:
18:29:30.479 dvb_ci/dvbci.cpp:1820 reset CI Slot 0: reset requested
18:29:33.621 dvb_ci/dvbci.cpp:1058 setInputSource eDVBCIInterfaces->setInputSource(0, 4)
18:29:33.622 dvb_ci/dvbci.cpp:2165 setSource CI Slot 0 setSource(0)
Conax18:29:41.433 dvb_ci/dvbci_camgr.cpp:78 setCAIDs eDVBCICAManagerSession::setCAIDs casCount = 10
18:29:41.433 dvb_ci/dvbci.cpp:635 recheckPMTHandlers The CI in Slot 0 has said it can handle caid 0b02... so use it
18:29:41.433 dvb_ci/dvbci.cpp:713 recheckPMTHandlers (1)CISlot 0, usecount now 1
18:29:41.434 dvb_ci/dvbci.cpp:1058 setInputSource eDVBCIInterfaces->setInputSource(0, 4)
18:29:41.434 dvb_ci/dvbci.cpp:2165 setSource CI Slot 0 setSource(0)
18:29:41.434 dvb_ci/dvbci.cpp:879 gotPMT [eDVBCIInterfaces] gotPMT
But it isn't the 0b02 card in the module but the 0b1d card. If I insert the module in another STB it sees correctly with the caid 0b1d and decodes my channels (although I hate my other STB :D )
As for the 0b1d caid, this isn't present in the CI Assignment menu so I cannot assign it manually either, also I tried to force it by the ci0.xml file, but did not help. Any ideas?
I really need mt 0b1d card to work on my VU+ Solo SE V2, because my other card is mostly used by my girlfriend on another STB suitable for her :) I just used my 0b02 card for testing purposes on the Solo SE V2.
After seeing that 0b1d isn't available on the Assignments plugin and that on other images say that it is reading my module with 0b02 even though it isn't the inserted card, I think there is something wrong with the CI module plugin generally, seeing the effect is the same in every single image I have tested. So any ideas? I must say that my module isn't a CI+ module, it's a classical Conax CI module
Thank you, any help would be welcomed.
