Ryan Attard
Hi all, i'm quite an amateur where it involves satellites and decoders. Recently I was turning on my vu+solo and the image on the tv did not show. i noticed that the green led light remained on and when trying to switch off the decoder there was no feedback - always on - not even in stand by- the only way was to turn it off from the plug because the device was getting very hot.
In 3 years this never happened. What I could conclude is that the day before I had a power cut and may be it was doing an update at that exact time.
Can anyone kindly suggest what I can do at this stage?
I've read that I have to flash it and install a new image using a pendrive. Can anyone indicate whether this is the correct path to take and any links are greatly appreciated. Btw, my decoder was using blackhole.
thanks
thanks
