VU+ Solo stuck.
camane007
Hello every one!
After years of very good performance, a couple of days ago when i tried to swish that stuck.
My Vu Solo does not switching on anymore. I can only see the red diod .
Any comment please
Thanks in advance
Thanks Matrix10, but could not see nothing to fix it for VU+ SOLO.
If you don't know electronics, it's hard to fix a hardware defect.
Some have repaired the box by replacing the capacitors.
That's what it says there.
I've never had a defect and I can't help you.
Besides, you have a lot on the internet about the defect of solo box.
Very rarely I've seen and read so many useful info about a hardware problem!
But clearly, it depends on how much you know about electronics, as Matrix said.
Summarising, these kind of problems depend, 99% of times, either on the capacitors or on the power supply. There isn't much more to say.
If you are not a technician (and surely you aren't) look for one and let he get your box fixed.
