VU+ Solo tuner power problem.
deanoz123
Hi, I seem to have a problem with the VU+ solo tuner.
The motor's green power light isn't lighting up when its connected to the solo, it does when it is connected to the old technomate box so I know it isn't the motor.
Any ideas??
Thanks in advance.
Any ideas??
Thanks in advance.
Probably your PSU is broken and should be changed.
I have some similar problem with a Vu SOLO SE 3 months old. I can watch channels but when I switch off at night and I come back from work turn it on and I get tune failed. I have to remove the motor dish feed from the back and plug it back, then I get the channels again. I haven't check the motor green light though
Will that be the same issue or the tuner?
Ask replace tuner to your reseller.
