Vu+ solo v2 Open atv .Problem with projector 24fps
irlandczyk007
Hi.i just connected my optoma hd27e projector. There is poroblem with sport.Picture lusing sharpness when scene is fast.
Problem is
Frame Doubling Interpolation (SmoothVideo Project)
Is it any plugin any settings to make my picture more smooth?
Thanks
How do you connect your projector? I suppose by HDMI.
Under A/V settings of BH, try to disable the Automatic Resolution; then, instead of the "Multi" refresh rate, try different rates (50Hz or 60Hz).
This is the only video option related to your issue available under OBH orBH, if I'm not wrong.
Can you upload pictures how to do it.thanks
