Hi all,
Bit of a problem here. I have Blackhole running on the box.
When i switch to standby and press the red button on the remote control to restart, the box starts.
When i put the box into deep standby the box will not boot, all i get is a red and green light on the front of the box.
I have switched the box off at the mains and removed the plug from the socket i left it overnight tried it again in the morning - no cigar - red and green light on box.
Re flashed the box (after many failed attempts) to the blackhole image. Ran a satellite search, did not install anything on the box bar the satellite feed 28.2.
Put the box to deep standby - red, green light on box. - no boot.
Tried it with a Vix image - same problem.
No USB's or External hard drives were connected to the box while i was doing this.
The box works perfectly when it is on or woken from standby - the problem occurs when the box is put into deep standby.
Any ideas? Seems something has been corrupted somewhere along the line?
Have no idea what.
Any help would be great.
Have no idea what.
