vu+solo
ken897
HI I AM TRYING TO UPDATE THE BLACKHOLE IMAGE AFTER FINISHED IT CAME ON GREEN SCREEN AND NOW IS ON THE BLACKHOLE IMAGE ITS BEEN FOR A WHILE ANYONE HELP PLEASE?
Just connect it in before to switch on the receiver and then configure it in tuner settings.
If you can see the tuner in Choose Tuner panel, check again your tuner configuration.
You should set the tuner as Europe, Middle East, Africa: DVB-T Frequencies.
If the tuner is not displayed in tuner list or there are other problems, report it in Black Hole Usb Tuners Drivers section and remeber to report aslo the tuner model , version ecc.
