vu+ solo2 - 2.1.5 - no tuner working
ctrl
hi experts,
I had installed 2.1.5 on my vu+ solo2.
After a few days it hanged on and no more tuners were working.
I flashed it again and same problem...no tuner was working.
I did downgrade to 2.1.4 now and this one is working....any ideas what is the problem here with 2.1.5?
hi experts,
U may have a corrupted Downloaded BH 2.1.5 file, try again with a new file!
What settings have you got the VU+ Tuners set up as?
Can you please provide more details regarding your set up, is it a fixed dish, motorized dish, twin LNB, 2 separate LNB's ?
Are you using a motorized dish, or fixed dish, on one satellite?
If using a Motorized dish, and twin LNB, with two cables going to your receiver, one to Tuner A, the second to Tuner B, and using a Usals motor, then set the Tuner, connected to your motor, e.g. Tuner A, as Simple, Mode = positioner, and enter your latitude, and longitude details, you then set the other tuner, in this case tuner B, to second cable of motorized dish.
If it's a fixed dish then it's just simple, fixed, and the satellite, e.g. Thor 0.8W, and the second tuner as equal to Tuner A.
