VU+ Solo2, DVB-T stick not visible
T33
Hello,
I have an old DVB-T USB stick that plugged in to my new lovely Solo2 gives the following info (I have also included the full dmsg as a file) but is not visible in the tuner search section of the Setup. What could be wrong?
cat /proc/bus/usb/devices:
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1498 ProdID=a090 Rev= 0.94
S: Manufacturer=ULi Electronics
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=dvb_usb_m920x
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 0 Alt= 1 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=dvb_usb_m920x
DMesg:
dvb-usb: found a 'Dposh DVB-T USB2.0' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-dposh-01.fw'
usb 1-1: USB disconnect, device number 2
usbcore: registered new interface driver dvb_usb_m920x
usb 1-1: new high-speed USB device number 3 using ehci-brcm
dvb-usb: found a 'Dposh DVB-T USB2.0' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Dposh DVB-T USB2.0)
dvb-usb: no frontend was attached by 'Dposh DVB-T USB2.0'
dvb-usb: Dposh DVB-T USB2.0 successfully initialized and connected.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: Link up, 1000 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
