Vu+ Solo2 Freezes on a regular basis
termostat
Hi there,
I hope someone here can help me with finding where the problem is with my Solo2 box - it freezes every single day , sometimes even twice or three times a day.
The only way to get it back is to unplug the power. It is running BH 2.05.
If I'd only know where to start and what logs to review to find out if it is a plugin or something else causing it?
Thank you for any suggestions.
Below is the only Log from \\Solo2\Configuration\tmp that I can see some type of failrure but still can't tell if this is the reason or what it is?
[1970/01/01 01:00:07, 1] lib/account_pol.c:account_policy_get(286)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
[1970/01/01 01:00:17, 0] /Abuild/Bh2/openvuplus/build/vusolo2/tmp/work/mips32el-oe-linux/samba/samba-3.0.37-r2-vuplus3/samba-3.0.37/source/lib/pidfile.c:pidfile_create(112)
ERROR: smbd is already running. File /var/run/smbd.pid exists and process id 502 is running.
[2013/11/16 14:18:24, 1] smbd/service.c:make_connection_snum(1042)
192.168.1.10 (192.168.1.10) connect to service Harddisk initially as user root (uid=0, gid=0) (pid 13428)
192.168.1.10 (192.168.1.10) connect to service Configuration initially as user root (uid=0, gid=0) (pid 13428)
[2013/11/16 14:18:36, 1] smbd/service.c:close_cnum(1239)
192.168.1.10 (192.168.1.10) closed connection to service Harddisk
[2013/11/16 14:21:50, 0] printing/pcap.c:pcap_cache_reload(159)
Unable to open printcap file /etc/printcap for read!
