hubo19
Hi,
I'd like to ask for some help, maybe somebody can figure out what I am doing wrong.
I have 5 Vu solo 2 receivers as streaming servers (with dishes connected and everything). These "server" receivers has VIX openvix-Apollo.079-vusolo2 images installed, nothing else, no fancy skins.
On the other side I have 5 solo2 receivers with the same Vix images, with remote channel stream converter extensions, and each "client" receiver connects to one "server" receiver. Streaming not working perfectly, HD is freezing but this is a different problem.
If I leave the servers in standby mode, the clients can stream all the channels from the servers. But if the servers are in standby for too long, the enigma2 or something stops, the channels are faded in the channel lists, and the clients shows a message "no free tuner".
So I tried to restart all the servers every midnight, then put them in standby. And because when the server is restarting, the client could loose the connection, I restart the clients too, just after the server starts a restart procedure.
And here I am now, the servers are restarting just fine, but the client are totally stopped when they are restarted just after the server has restarted. No web interface, no response for ping, can't connect with ssh. Just manual restart helps, with the button on the back.
How can I stop the servers from freezing? Is it a Vix image issue?
