vu+SOLO2 HELP
aa7590
need lnb config for vu+solo2 blackhole image 2.1.5
lnb type is c band onecble solution lnbf 200k how to config this lnb only experts to answer that thing ok
Go into the tuner menu, tuner Configuration, select your Tuner and change the mode to Advanced. You can then set the LOF to C Band.
