VU + SOLO2 in vertical position.
mataviejas
Hello.
I do not have space in the new tv cabinet to place the VU + SOLO2 in horizontal position.
It is possible to place the SOLO2 VU in vertical position. Would there be a problem with the temperature dissipation?
You
you should put in normal horizontal position.
Can you eat or sleep upside down ??
Yes.
If the astronauts.
The deco does not sleep or eat, you just need to move the air with a fan on the cover of 1000rpm and solved issue, the new fan is not heard.
PD: 31-12-2018 the other day, more old post.??
