VU+ Solo2 Kernel Panic
pip268
I've been searching the threads and reading up on problems with my box stuck on "Starting".
Image is BH (can't remember which version).
It was working fine until I accidently pulled the power plug out.
Now when I start it I get the BackHole logo on the TV screen and the box display just says "starting".
Having read up on how to connect a serial port I got the boot log.
The part where the error starts is :-
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix H27U2G8F2CTR-BC)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000004620000
nand_read_bbt: bad block at 0x000009640000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
UBI error: check_corruption: PEB 25 contains corrupted VID header, and the data does not contain all 0xFF
UBI error: check_corruption: this may be a non-UBI PEB or a severe VID header corruption which requires manual inspection
Volume identifier header dump:
magic 55c241a1
version 1
vol_type 1
copy_flag 64
compat 32
vol_id 256
lnum 7
data_size 64
used_ebs 268435456
data_pad 16
sqnum 2305984021579956224
hdr_crc 947ddd7f
Volume identifier header hexdump:
hexdump of PEB 25 offset 4096, length 126976
UBI error: scan_peb: bad image sequence number 153896872 in PEB 92, expected 1030351679
Erase counter header dump:
magic 0x55424923
version 1
ec 3
vid_hdr_offset 2048
data_offset 4096
image_seq 153896872
hdr_crc 0xce46496d
erase counter header hexdump:
UBI error: ubi_attach_mtd_dev: failed to attach mtd0, error -22
UBI error: ubi_init: cannot attach mtd0
ALSA device list:
No soundcards found.
UBIFS error (pid 1): ubifs_mount: cannot open "ubi0:rootfs", error -19
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1): error -19
Please append a correct "root=" boot option; here are the available partitions:
1f00 230400 mtdblock0 (driver?)
1f01 230400 mtdblock1 (driver?)
1f02 7168 mtdblock2 (driver?)
1f03 1024 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
Rebooting in 180 seconds..random: nonblocking pool is initialized
It then proceeds to reboot after 180 seconds to give the same error.
Anybody know if it is bricked or can it be salvaged?
@pip268
Just read your message and can find the answer...
