VU+ Solo2 Remote Control
said006
Hi,
I have configured my TV with the remote control of my VU+ Solo2. The effect is that I can turn on and off the TV, and use volume control with the remote of my VU+ Solo2.
Is it possible to keep using the volume controls to control the VU+ Solo2 box volume instead of the TV Control? HMDI-CEC did not help. But I do want to use the remote only for turning the TV on and off, nothing else.
Is there a tool or a config that can be changed to realize this? Thank you very mucho in advance!
Hi,
Look at this:
1. Press 1and 6 for three seconds until LED is on.
2. Press <9>, <9>, <3>.
3. If you want to control of TV volume, press TV Power button. If you want to control STB volume, press STB Power button
Look at this:
Thanks a lot man. This helped!!!
i don't know the forum rules
but can anyone HELP i need to upload files to vuo duo from filezilla I'm okay up to etc/enigma from here where do i go to paste etc grateful thanks
