VU+SOLO2 stuck on STARTING...
greenshare
Hi all
i was watching tv and boom my vu+solo2 restarted itself and it says : STARTING with the OLD blackhole logo not the bleu one and not the one before.. the really old one..
I tryed Flashing it but i keep getting UBISF UPDATE... i changed alot of USBs and all PORTS i formatted USB with fat 32.....
i dont know wich prog to use for real com port and where i can find the NFI file if there is one
Can somebody help me ??
THANKS
Hi all
THANKS
It is of my knowledge, it is impossible
Are you sure your box is an original solo2 ?
