vu+solo2 tunner tunner stuck last two weaks not searching any channal now i check cables and lnbs r all ok now tell how to fix this issue only experts answer in urgent waiting
I buyed vu solo2 and vu duo2You now have a couple of threads, on the same subject:
http://www.vuplus-community.net/board/threads/solo2-tunner.24391/#post-183166
The problem still remailns that you haven't posted any real information.
Dish set up:
You mention it's fixed, which satellite is it pointing at?
How many LNB's do you have connected to the dish, just 1 or more?
How many cables are coming from the LNB to your receiver?
Which tuner is connected, if only 1 cable?
What settings, do you have, in the Tuner Configuration?
Go into the Menu, Setup, Service Searching, Tuner Configuration, select which tuner is being used and please post the configuration.
HiWhy haven't you started your own thread?
There aren't any problems, with either of those frequencies, for me, using a genuine VU+ Duo 2, and running Black Hole 2.1.5.
Where is your general location?
What size dish are you using?
What are your signal quality readings, for other channels, on Hotbird, 13E?
On my Solo2 OBH haveI buyed vu solo2 and vu duo2
Both of them have problem with alot of ferequency
For example i can search channel with solo 1 and vu duo 1
But with solo 2 and vu duo 2 dont have any sugnal
12476
12692
Hotbird
But with solo 1 this channels are good
