Solo2 is a DVB-S/S2 STB. If your reference satellite transmit with these standards it's compatible. For more infos, it's better than you report what satellites you want to tune.
so here in Brazil using the system 3, cs, iptv, sks, sks is the most used used two satellites the StarOne 70w c2 to watch the channels, and 30w hispasat we get the key to the devices you have here is also twin and has two tuner...
Hello friend, refereça star satellite of a C2-70W broadcasts in DVB-C DVB-S DVB-S2, the question is, does the vu + solo work like the other receivers we have here in sks mode?
