Hi want to put autobouquets and dvdsnoop on to above box I know I have to ftp it using dcc I know I have got to transfer it from pc to box but can some one tell me where it has to go please appreciate any help mialy
I dont know for what is autobouqets. For dvbsnoop there is no need to install and binary can reside in usb stick or in flash like /usr/bin , /usr/sbin and so on
If you have autobouquets ipk file you ftp that to the tmp folder on your box.Then go to the main menu/addons/manually install ipk packages and your AB file should be there.Once installed it'll ask you to restart enigma.Your autobouquets should now be in your plugins
