VU+ streaming udp/multicast
jurim
Hi all!
Before I buy Vu+ receiver, I need to know if it would fit my needs.
I have read a lot of posts, but still haven't found answer for my question.
I know I can receive udp/multicast streams with Vu+. I also know Vu+ can stream http and I can watch these streams on PC (or any device which supports http stream). But is there any plugin that could stream udp/multicast? I know I can receive http stream and convert it to udp using VLC, but is there any way to do it direct from receiver?
Spanish support... ;)
Que modelo de Vu+ tienes?
El streaming que buscas, te lo ofrece el Vu+ Duo2
Saludos
Thank you Saldus!
At the moment I don't have any Vu+, I plan to buy one. OK, will choose Vu+ Duo2 then. I guess some plugin is needed for streaming - what for should I search?
When I posted, saw that this is "Vu+ Official", somehow missed it's Spanish :D! But Google translate works fine :).
Yes it´s Vu+ Official forum but you are in the Spanish section, so you can write in english better HERE
Regards from Spain ;)
